New Series of Air Springs from AAC
By Patrick Curran | March 3, 2010
New Hyde Park NY – A new series of air spring vibration mounts from Advanced Antivibration Components (AAC) feature excellent vibration isolation of low frequency machines. Air springs use elasticity of air as an isolator which act as a soft spring. There are no moving parts and are therefore maintenance free. These mounts handle a wide range of loads simply by changing the inner air pressure. These mounts are featured at the AAC eStore where you can order online, request a quote, download CAD models, check stock plus view catalog and technical pages.
AAC-Air-Springs
These metric isolators, identified as the V11Z48MPSB… Series have applications in: oscillating conveyors, laundry machines, centrifugal separators, air compressors, water pumps, generators, and air blowers. They can also be used as actuators in tensioning devices. The bellows are made of synthetic rubber which incorporates a reinforced cord and wire. The clamping rings and the upper and lower plates are made of stainless steel.
Antivibration Components – AAC
http://vibrationmounts.com/NewProducts/Air_Springs.htm
Filed Under: Springs • wave springs • retaining rings • spring clips, Shocks + vibration control • gas springs
