New sizes for designer table-top enclosures
By Lee Teschler | November 4, 2021
OKW has added a new 125 size to its elegant EVOTEC range of designer table-top plastic enclosures. Designers specify tough but soft-contoured EVOTEC for applications including measurement and control, IT, IoT/IIoT, gateways, medical, laboratory and environmental technology.
The new EVOTEC 125 size has a smooth flat top. This two-part enclosure features a robust tongue-and-groove design. It can be specified with IP 65 ingress okwprotection (optional) and is assembled with tamperproof Torx stainless steel screws – a key requirement for medical devices. PCBs can be mounted on screw pillars in the top and base. Rubber feet ensure stable positioning on flat surfaces.
EVOTEC is available in three versions, offering the choice of a sloping top (either with or without a recess) or a smooth flat top. The range now comprises EVOTEC 80, 100, 125, 150, 200 and 250, giving a wide choice of sizes from 3.15×1.96×0.86 in to 9.84×6.10×2.12 in. New EVOTEC 125 is available in one version (smooth flat top) and two heights: 4.92×3.07×1.18in/1.45 in.
All the enclosures are molded from off-white (RAL 9002) UV-stable ASA+PC-FR (UL 94 V-0) as standard. Prices for EVOTEC start at $19. Accessories include IP 65 seals, a wall suspension element, a mounting bracket for DIN rails (TH35, G32), self-tapping PCB screws (PZ1, Torx T8) and a Torx T8 screwdriver for assembly.
OKW can supply EVOTEC fully customized. Services include CNC machining; lacquering; product labels; RFI/EMI shielding; printing or laser marking of legends and
logos; installation and assembly of accessories.
OKW Enclosures, Inc. 3000 Old Pond Road, Bridgeville, PA 15017, 412 220 9244, (800) 965-9872, Fax: 412 220 9247, E-mail: [email protected], https://www.okwenclosures.com/en/Plastic-enclosures/Evotec.htm
You may also like:
  • 9-11 truthers
    The WTC collapse after two decades
  • scilab
    The top ten free engineering math software packages
  • don't worry about EV fires
    Don’t worry about EV fires
  • electrocaloric cooling
    Keeping cool with capacitors
  • pie in the sky
    Sizing up renewable energy aspirations
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
Tagged With: okwenclosures
okw
Control knobs cater to menu-driven electronics
metcase
Standard and customized 19-in rack cases, mini-racks, desktop and portable instrument enclosures
metcase
New 19-in enclosures meet latest DIN 41494, IEC 60297-3 standard
leadertech
EMI shielding kit includes fingerstock EMI gaskets in various shapes, sizes, and finishes
