JW Winco, Inc., a supplier of standard industrial machine components, now has slam latches available — with or without lock. The new GN 936 Slam Latches Zinc Die-Cast let doors and closures close effortlessly. The lockable versions are each supplied with two keys, which are removable in both the open and locked positions.
“The latch engages automatically when the door is closed, preventing the door from opening unintentionally,” explains John Winkler, CEO, Office of the President at JW Winco. “The slots enable the slam latch to be assembled to aluminum profile systems with different cross-sections.”
The housing of the slam latches is zinc die-cast, powder coated, and has either a black or silver textured finish. The cover and latch are plastic and come in either black-gray or light gray. The lock mechanism is zinc die-cast while the key is steel and nickel plated.
JW Winco
www.jwwinco.com
Filed Under: Clamps • locks • latches
