New study on oil-lubricated shaft systems
By Mike Santora | September 25, 2018
Thordon-Bearings-Propeller-ship-in-dry-dockThordon Bearings has published a study highlighting the commercial and environmental benefits of seawater-lubricated propeller shaft bearing arrangements, indicating that shipowners can make substantial operational savings by giving up the outdated oil lubricated shaft.
The study, the findings of which were presented for the first time during the SMM 2018 trade fair in Hamburg, Germany, was carried out in response to the increase in oil and oil-based Environmentally Acceptable Lubricant (EAL) lubricated sterntube bearing failures, which are placing an additional and unnecessary financial burden on shipowners.
Despite the introduction of legislation to reduce shipping’s impact on the oceans, together with shipowners’ ever-present need to reduce operational costs, the majority of commercial ocean-going vessels continue to use a system that is increasing risk and is costly to operate.
“It is quite staggering that over 95% of all new commercial ships continue to be built with oil lubricated propeller shafts – a system that is not only operationally expensive but environmentally questionable,” said Craig Carter, Thordon Bearing’s Director of Marketing and Customer Service.
“Our Future, Our Ocean paper presents the case for water lubrication to shipowners and shipbuilders as a commercially and technically viable way of increasing profits while achieving corporate sustainability goals.”
The 14-page document explains that while the low capital expenditure of an oil-lubricated system is an obvious attraction, any financial advantage is completely lost once the vessel enters the water. This, cites Thordon Bearings, is due to the costs associated with purchasing lubricating oils, the regular maintenance and unscheduled drydockings required to repair or replace faulty shaft seals.
While emergency seal repairs alone can cost anywhere from US$150,000 to US$300,000, excluding drydock costs, the paper furthers that the constant topping up of an oil-lubricated system, combined with the regularity of aft seal failure, can cost shipowners in excess of US$6.5 billion over a twenty-five-year period.
The paper reveals that for a typical single screw bulk carrier turning a 650mm shaft, the total cost of operating an oil-lubricated system over 25 years (including capital investment) is US$605,925 against $370,000 for a seawater-lubricated arrangement.
Although part of the cost of operating an oil-lubricated system is dependent on oil price fluctuations and does not take into account the use of more expensive EALs, the use of seawater as the lubricating medium is obviously free of cost.
“While the environmental impact of oil leaking from sterntubes has been well documented, the commercial impact on the shipowners bottom line has not been addressed. This study intends to raise awareness of the commercial disadvantages from the continued use of oil lubricated propeller shaft bearing systems, while offering a more cost-effective and more environmentally acceptable solution,” said Carter.
Thordon Bearings
thordonbearings.com
Filed Under: Uncategorized
Tagged With: thordonbearings
