New subminiature pilot solenoid valves
By Andrew Zistler | January 4, 2016
Mini 068_CMYK_1Solenoid Solutions Inc is now offering a further evolution solenoid valve, the 10mm and 15mm direct acting and pilot valves for the pneumatic automation and instrumentation market.
The 10mm and 15mm solenoid valves are designed for those air and inert gas applications where high performance in the areas of pressure and flow are required together with small size, very low power consumption and high reliability even at high cycling rates. And all Solenoid Solutions 10mm and 15mm solenoid valves are suitable for oxygen service.
The 10mm and 15mm solenoid valves are made with an encapsulated coil joined to a valve body. The assembly is non-detachable.
Solenoid Solutions Inc.
solenoidsolutionsinc.com
Filed Under: Solenoids
Tagged With: solenoidsolutions
