Fox Electronics (Fort Myers, FA) now offers the FTM Series of surface mount OCXOs that is ideally suited as the timing reference for network synchronization. The new SMD OCXO offers specifications suitable for communication equipment, including base stations, radio network controllers, wireless backhaul equipment, and routers, as well as gateways, PON (Passive Optical Network), DSLAM (Digital Subscriber Line Access Multiplexer), multi-service switching platform, and transmission equipment. Features include:
- Standard stability of ±10 ppb across a set of standard frequencies in the 5 MHz to 40 MHz range with temperatures from -40° to +85°C and stabilities as tight as ±5 ppb available.
- Frequency control pin that allows a minimum of ±0.7 ppm of frequency adjustment.
- SMD oscillator comes with a 3.3 VDC supply voltage, with 5 VDC as an option, and operates at a maximum of 1.2 W at 25°C.
- Output load of 15 pF and long term aging over 10 years is only 0.4 ppm for all effects.
For more information, visit www.foxonline.com.
