    • Subscribe!
New Tech Developed for Low-Vibration Sawing & Sanding
By atesmeh | March 30, 2015
FEIN’s versatile power tool vibrates up to 70 percent less and is only half as loud as its predecessor. Image credit: C. & E. Fein GmbHNo matter whether it’s a drill or an oscillator, handheld power tools produce powerful vibrations.
But a new anti-vibration system almost entirely eliminates that uncomfortable shaking sensation you get when using such tools: The FEIN MultiMaster oscillator vibrates up to 70 percent less and is only half as loud as its predecessor. Fraunhofer researchers developed the technology in collaboration with FEIN and will be presenting the system at Hannover Messe (Hall 2, Booth C22) from April 13 to 17, 2015.
If you’ve spent extended periods of time working with a drill or some other handheld power tool, you’ll know how quickly you’re longing to give your poor arms a rest. No wonder, either – such devices tend to vibrate a lot and be very loud.
In the future, you’ll experience far lower vibrations when you want to drill, saw or sand something. Researchers from the Fraunhofer Institute for Structural Durability and System Reliability LBF in Darmstadt teamed up with their colleagues at C. & E. Fein GmbH to develop a technology to dramatically reduce vibrations.
“We examined how the system is set up and refined it so it can be applied to a range of handheld power tools,” explains Heiko Atzrodt, group manager at Fraunhofer LBF. And this is precisely what FEIN has done to one of its oscillating power tools – in other words, a tool that doesn’t have a rotating action, but rather one that moves back and forth almost 19,500 times a minute.
These and similar tools can do more than saw and sand; they are just as adept at rasping, polishing, shaving, cutting, severing, sharpening and filing – including at those hard-to-reach places.
Decoupling the housing from the motor
So how did the researchers manage to dramatically reduce how much handheld power tools vibrate?
“Elastomer elements are used to decouple the housing from the motor and act like a form of mechanical suspension and insulation,” says Atzrodt. What this means is that only a tiny portion of motor vibrations are transferred to the housing and so to the user.
You can, however, have too much of a good thing: If the researchers were to insulate the housing too much, users would be unable to feel how hard they were pressing the tool onto whatever material they’re working with. So the researchers had to strike a balance between reducing vibrations and allowing users to retain a feel for what the tool is doing. This comes down to adjusting the stiffness of the elastomer elements. First, the researchers used a simulation to determine the ideal stiffness range before integrating various suspension and insulation devices into a test system. This in turn allowed them to set the basic development parameters.
Up to 70 percent lower vibrations, 50 percent less noise
“By applying the anti-vibration system, FEIN was able to reduce vibrations by up to 70 percent compared to previous models,” says Atzrodt. “For almost all applications, the oscillator now belongs squarely in the zero vibration class.”
Since this makes it permissible to work with this tool for up to eight hours at a time, technicians or autoworkers can now use it throughout their shift. The tool is also easier on the ears: Thanks to the new insulation, it now produces 50 percent less acoustic pressure.
This low-vibration oscillator is now on the market under the name FEIN MultiMaster FMM 350 Q. At Hannover Messe, the Fraunhofer LBF researchers will be offering visitors the chance to feel the difference for themselves by demonstrating the new-and-improved oscillator next to its predecessor.
Entries Open: Establish your company as a technology leader. For 50 years, the R&D 100 Awards, widely recognized as the “Oscars of Invention,” have showcased products of technological significance. Learn more.
    • Subscribe!
