Schaumburg, IL — The Type RU Roller Ring from THK features compact, yet highly rigid construction. The double-row roller structure and integrated inner and outer rings of the Type RU result in 20 to 30 percent higher rigidity than competitor models.
THK Double RU
The Type RU’s use of small rollers reduces differential slip and therefore the torque required for rotation is small.
Installing the Type RU is easy due to the inclusion of mounting holes on the inner and outer rings. Housings and presser flanges are not required, and few assembly parts are needed. Design configuration is flexible per customer specifications.
THK manufacturers the widest range of linear motion products including conventional LM guides, ball screws, mechanical actuators and ball splines and more. All THK products have been designed and manufactured to meet the strictest requirements. THK’s experienced Global Engineering Team can provide customized linear motion solutions with our standard linear motion products as well as our mechatronics products for your most demanding applications.
To learn more, log on to www.thk.com or contact THK America, Inc., 200 E. Commerce Dr., Schaumburg, IL 60173, Phone: (847) 310-1111, Fax: (847) 310-1182, e-mail: [email protected].
Filed Under: Factory automation, Ball screws • lead screws, Bearings, Mechanical, Motion control • motor controls
