New Twelve-Megapixel CMOS Camera for Machine Vision
By Design World Staff | June 4, 2008
IRVINE, CA ‚– Toshiba Teli America, Inc. introduces a CMOS-based machine vision camera boasting a proprietary and patented twelve-megapixel 1.9-inch CMOS monochrome progressive scan sensor.
The new Toshiba Teli CleverDragon CSC12M25BMP19 establishes an optimal imaging platform to assist OEMs and system integrators in developing improved solutions for high-speed machine vision, parts inspection, robotics and medical applications.
Users benefit greatly from the camera‚’s CMOS sensor‚’s 4096 (H) x 3072 (V) pixel resolution, along with its excellent 25-frames-per-second (fps) full-frame speed, and its low signal-to-noise ratio that is close to a traditional CCD. The development environment for the CSC12M25BMP19 is further enhanced by its Camera Link‚â„¢ standard interface (10/8 bit), allowing for immediate integration of the camera into new and existing systems without the need for special cables or frame grabbers.
In keeping with Toshiba Teli‚’s productivity-driven philosophy, the industrially rugged yet compact CSC12M25BMP19 features an electronic global shutter to capture clear images of parts on even the fastest moving assembly lines. In addition, the camera‚’s Window of Interest (WOI) function can be programmed to display a maximum of 28 square windows within a single image and then allow the user to select via a PC only those windows that are to be read out, significantly increasing fps rate.
Other key features include large square pixels (6.0‚µm x 6.0‚µm), an aspect ratio of 4:3, high sensitivity of 2000 lx (F5.6), wide dynamic range, and RDM trigger shutter.
www.toshiba-teli.com
Filed Under: Electronics • electrical, Vision • machine vision • cameras + lenses • frame grabbers • optical filters
molex-premo-flex
