The Lapp Group has developed a new flexible servo cable, ÖLFLEX SERVO 719 CY, that targets a broad range of motor-drive systems and application requirements.
Designed to be a universal servo cable, ÖLFLEX SERVO 719 CY allows machine builders and installers to specify and stock fewer servo cables when working with multiple servo systems.
Consisting of three power and one protective ground conductors plus one or two optional control pairs, the features of this EMI-shielded cable include:
- Overall tinned copper braid shielding
- Thinner outer diameter than comparable UL-certified cables to save space and weight
- Low capacitance design to increase the length of cable runs
- Compliance with multiple standards
- UL AWM Style 2570
- Flame Retardant VW-1
- cRU AWM I/II A/B FT1
- CE
- RoHS
With its mix of properties and approvals, ÖLFLEX SERVO 719 CY can serve as a drop-in-replacement for our ÖLFLEX SERVO 700 CY and ÖLFLEX SERVO 709 CY cables.
Lapp Group
www.lappusa.com
The post New universal servo cable appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
