    • Subscribe!
New Valveless, Fluid Transfer Pump For Analytical Instrumentation
By Frank Tobe | June 23, 2017
The valveless Fluid Transfer Pump from Fluid Metering, Inc. delivers precision fluid control for analytical instrumentation.
Transfer-PumpFMI’s Valveless, Fluid Transfer Pump integrates CeramPump® pumping technology with the long life performance of a brushless DC motor and integral driver electronics. All that is needed is a simple 24VDC input power supply making FMI’s Fluid Transfer Pump an easy drop-in for existing instrumentation designs.
FMI’s unique CeramPump® valveless piston fluid control technology utilizes one moving part, a rotating and reciprocating ceramic piston to accomplish all fluid control functions within the pump, thereby eliminating the need for check valves typical of reciprocating pump designs. Sapphire-hard, dimensionally stable ceramic internal components substantially outperform peristatic pumps, whose accuracy is dependent on the memory and integrity of flexible tubing.
www.fluidmetering.com
Filed Under: Hydraulic equipment + components, Pumps
Tagged With: fluidmetering
ironhorse-AD-jet-pump-image
IronHorse jet pump and stainless steel motors from AutomationDirect
KNF’s Diaphragm Liquid Pump FP 70 provides a smooth flow and high efficiency solution
KNF’s new smooth flow, high efficiency diaphragm liquid pump FP 70
spartan scientific high-pressure solenoid pump
High-pressure solenoid pump offers fluid control for rigorous needs
    • Subscribe!
