New WD-40 specialist greases prevent cross-contamination
By Mike Santora | March 23, 2017
WD-40-grease-bundle-imageBecause using the right grease for the job can prevent expensive equipment damage, WD-40 Company is introducing WD-40 Specialist Greases, a family of lubricants for automotive, construction and farming professionals dealing with a variety of specialized lubrication challenges.
The WD-40 Specialist Greases line includes Superior Performance True Multi-Purpose Grease, Heavy-Duty High-Temperature Grease, Heavy-Duty Extreme Pressure Grease and Marine-Grade Water Resistant Grease. The products are interchangeable with each other, meaning they won’t cause cross-contamination issues that compromise performance and effectiveness. The greases also excel in extreme conditions and protect against rust and corrosion.
The lithium complex-based greases in the WD-40 Specialist line of products offer the following benefits:
· Heavy-Duty High-temperature Grease: Engineered to withstand heavy mechanical loads and extreme temperatures, it is suitable for heavy-duty trucks, construction and agriculture equipment.
· Heavy-Duty Extreme Pressure Grease: With exceptional load-carrying ability, anti-wear protection and high dropping point properties, it can be used in a variety of automotive, construction and agricultural applications.
· Marine-Grade Water Resistant Grease: Engineered to stay in place in the presence of water and provide superior rust and corrosion protection in wet environments, it can be used on trailer wheel bearings, trailer chassis, water pumps, anchor reels and outboard motors.
WD-40
WD40Specialist.com
Filed Under: Lubrication, Bearings
Tagged With: WD-40
  • Tech Toolbox: Designing for cleanrooms
