Researchers at Universiti Teknologi MARA in Malaysia have succeeded in using ionized gas in a common fluorescent light tube as an antenna for a Wi-Fi Internet router.
Wi-Fi routers are essentially two-way radios that connect digital devices to the Internet. But in many buildings, providing complete coverage is a challenge. Radio “dead spots” can occur in areas where solid walls or appliances block a router’s signal entirely, or degrade it to become so weak that a portable Wi-Fi device, such as a tablet or phone, cannot connect reliably.
When electricity flows through the argon-mercury vapor in a fluorescent tube, it forms an ionized gas or plasma. Plasma has conducting properties comparable to a common metal radio antenna.
This allows an attached router to send and receive radio signals through the light tube on the standard 2.4-gigahertz Wi-Fi frequency in exactly the same way it does through a regular antenna. The router’s radio waves can ionise the gas in the tube, so it acts as an antenna whether the light is on or off.
According to the research team, the plasma found in a standard 62-centimeter light tube is highly conductive and signal measurements on a test device show that it’s strong and stable.
Thus plasma compares favorably with standard metal Wi-Fi antennas for transmitting and receiving. The prototype antenna consists of a fluorescent tube that connects to the router through a tuned wire coil in a sleeve slipped over one end. The coil passes the router’s radio signal through the glass of the fluorescent tube and into the plasma.
The team says that multiple antennas could be connected to a single router through a building’s electrical wiring using existing Wi-Fi standards. This would create a separate antenna in every room where there is a dedicated fluorescent light fixture and provide low cost building-wide wireless Internet coverage.
Further studies by the team may include adding more fluorescent tubes in various configurations to investigate the capability and performance of multiple plasma antenna arrays. One possible application could involve installing this technology in outdoor billboard lights. Each plasma antenna array would then be integrated with a Wi-Fi router to provide large-scale, system-wide wireless communication.
