While many nylon-12 tubing suppliers have been faced with sourcing raw materials during a recent worldwide shortage, NewAge Industries worked diligently with its partners to obtain materials and finished tubing. The company has an ample supply of nylon-12 tubing at a time when other businesses are still scrambling to source and manufacture the product.
The shortage of nylon-12 tubing came about because of several issues. First, a good number of nylons, including nylon-12, are petroleum-based. Oil supplies, demand, and prices have been volatile in recent years, and many types of plastic have been impacted. In addition to nylon, raw material costs for PVC, polyethylene, and fluoropolymer have seen increases, and in some cases, shortages.
Second, the solar energy market took its toll on supply levels. Nylon is a solar panel component, although usage has now tapered off. Third, nylon-12 is a commonly used material for fiber optic cable jacketing, and expansive cabling projects have affected supplies.
While some of these crises have lessened, many tubing suppliers continue to have difficulty with raw material procurement.
“We’ve been working on this situation in earnest for months,” noted Catherine Wallace, NewAge Industries’ Director of Purchasing. “There are a limited number of nylon-12 manufacturers, and demand simply outpaced supply.”
NewAge’s nylon-12 tubing, Nylotube®, provides light weight combined with corrosion, abrasion, and chemical resistance. It withstands repeated flexing and is well suited for retractable coils. Nylotube also offers very low moisture absorption, plus excellent bend radii and pressure ratings. Applications include pneumatics and a wide variety of fluid transfer.
Nylotube is stocked in two grades – flexible and semi-rigid. Inch sizes up to 1” O.D. and metric sizes up to 12mm O.D. are available. Six colors are offered, making line identification quick and easy. NewAge also stocks nylon-11 tubing in limited supply.
NewAge Industries
www.newageindustries.com
Filed Under: Fluid power, Tubing components
I prefer silicone tubing than normal plastic or nylon tubes. Maybe it is a consequence of working a lot of years with this material, I know it has a lot of good propierties!
Laura
