NK Technologies’ ASXP Current Sensing Switch is available with a user-adjustable setpoint from 1-80A. ASXP Series Current Operated Switches are powered versions of the company’s current switches with integral time delay. For use with 24VAC/DC or 120VAC supplies, these switches deliver OEM-caliber accuracy, precision tolerances, low hysteresis and an operation range between 40 and 100 hertz – functionality ideal for monitoring single and three-phase motors. They come standard with a robust solid-core enclosure and LED indicators for trip point contact status.
The compact ASXP is a highly versatile option for single and three-phase motor monitoring, with a relay output that allows the sensor to be used to control NEMA size 1 contactor coils and other inductive loads. A fixed two-second delay trip timer eliminates nuisance alarms due to start-up inrush or temporary over-current conditions in motor or heater status applications, eliminating the need for a separate time delay relay.
In motor protection applications these sensors provide electronic proof-of-operation and detect current draw changes in the motor caused by pumps running dry or impending bearing failure. The ASXP is less expensive to install and serves as a non-intrusive alternative to differential pressure flow sensors or thermal switches. They also deliver quicker response times than Class 10 overload relays. Users will also benefit from repeatable performance, constant hysteresis and linear response.
NK TECHNOLOGIES
www.nktechnologies.com
Filed Under: Electronics • electrical, Switches
