Noise Cancelling Device Halves Noise Pollution Through Open Windows
By Nanyang Technological University | May 2, 2018
Nanyang Technological University, Singapore researchers have developed a device that can reduce noise pollution entering buildings even while windows are wide open. Designed to be mounted onto window grilles, the device could reduce up to 50 percent of noise coming from nearby environments such as busy roads, train tracks or from construction activities.
The device uses ‘active noise control’ technology—found in many high-end headphones that cancels external noise—that is adapted to work in a large open area. The benefits are two-fold: Windows can be left open for fresh air without disturbance from external noise pollution, and the device reduces the need for air-conditioning to keep the interiors of buildings and homes cool.
Professor Gan Woon Seng, Director for NTU’s Centre for Infocomm Technology (INFINITUS), who led the research said, “Compared to noise cancellation headphones, what we have achieved is far more technically challenging, as we needed to control the noise in a large open area, instead of just around the ear.
This noise cancellation technology is an example of research innovations that NTU is encouraging under its Smart Campus initiative, which aims to improve quality of life for society through the development of new sustainable and technological solutions and by trialling them on its campus first.
Using sound to remove noise
Currently at the prototype stage, the device uses 8 watts of power, similar to a small portable Bluetooth speaker. Several units are placed together to form a grid-like array on a window grille to reduce external noise.
The device uses a special sound-emitting mechanism that works like a speaker and is hooked up to a processing unit. Equipped with a microphone, it can detect noise even before it reaches the window and computes the attributes of the incoming noise in real-time.
Infographics showing how the noise cancellation device developed by NTU Singapore scientists can help reduce noise pollution by 50% while windows are wide open. Credit: NTU Singapore
It quickly emits a countering sound or “anti-noise” that has the same waveform characteristics of the invading noise but with one difference: it is inverted or “flipped.”
When both outside noise and anti-noise converge, they cancel each other out, resulting in a softer ambient sound entering living spaces.
“Our innovation not only computes the right amount and type of ‘anti-noise’ to emit, but also does it faster than the detected noise can reach inside the building,” explained Prof Gan, who teaches at NTU’s School of Electrical & Electronic Engineering.
The research team conducted the tests using a soundproof chamber at the university’s labs that houses a mock room with windows and doors, resembling a typical room in a home. Various recorded sounds from construction sites, jet engines and trains were used as noise sources during the tests.
They are now developing the technology further by improving its noise cancellation efficiency, and making the device smaller and more cost-effective to produce. Prof Gan said, “We are currently finding ways to improve the technology further so that it can be used not only at window grilles with large openings, but also provide a cost-effective solution that can be easily installed and replaced. Ultimately, we aim to integrate this technology into window grilles that can help mitigate urban noise pollution conveniently.”
The researchers are also working with government agencies in Singapore to further improve the technologyto make it viable for commercial and residential applications.
PCB mills
