Non-spill Quick Disconnect Couplings
By Design World Staff | May 12, 2011
Non-spill couplings enable leak-free connection and disconnection of critical fluid lines in liquid cooled servers, chillers and other electronic systems, without the risk of drips or spills. Available for tubing ID ranges from 1/8 in. (3.2 mm) to ¾ in. (19.0 mm), plastic and metal connectors alleviate concerns inherent in handling fluids in the vicinity of critical electronics. They feature color coding for visual line identification, a variety of seal materials for media compatibility, and a range of termination and thread types.
Non-spill couplings
Colder Products Company
www.colder.com
Filed Under: Couplings, Fastening + joining • locks • latches • pins, Fluid power, Hydraulic equipment + components
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
