Nordson EFD’s New BackPack™ Valve Actuator
By Patrick Curran | May 4, 2010
Nordson EFD’s new Backpack Valve Actuator can help companies produce more products in less time by cycling select EFD dispense valves 2 – 3 times faster than previously possible. The faster valve actuation also makes it possible to produce the smaller fluid deposits required in the assembly of many of today’s advanced products, such as medical devices and portable electronics.
Nordson-EFD-BackPack-Valve-Actuator
Incorporating advanced miniature solenoid technology, the innovative BackPack mounts the solenoid used to open and close the valve directly on the valve’s air cylinder, rather than on a separate fixture. This makes it possible to achieve valve actuation speeds as short as 5 – 6 milliseconds and cycle rates as high as 800 per minute. In contrast, typical valve actuation speeds and cycle rates are 15 milliseconds and 400 cycles.
Nordson EFD
www.nordsonefd.com
Filed Under: Actuators, Hydraulic equipment + components, Pneumatic equipment + components, Valves, Medical-device manufacture, FLUID POWER
