Nordson offers advanced two-part adhesives and sealants
By Michelle Froese | April 29, 2020
Learn more about Nordson’s Two-Component (2K) Products here.
Nordson EFD, a manufacturer of precision fluid dispensing systems, offers industrial mixing systems that are uniquely designed to accurately mix and dispense two-part adhesives and sealants while eliminating entrapped air.
The Two-Component (2K) industrial mixing systems, products, and mixer accessories are manufactured in the USA in facilities that are ISO 9001:2000 certified. The line comprises of  innovative Side x Side cartridges, including the collapsible Film-Pak and snap-together Ratio-Pak.
If you require help finding the right 2K dispensing system, download Nordson’s insightful 2K Selection Guide here .
In addition, Nordson also offer One-Component solutions, including EDF fluid dispenser systems and Optimum components:
  • EFD fluid dispensers, which provide much greater control than the typical squeeze bottles, swabs, and hand syringes used in manual assembly processes.Nordson offer a wide range of fluid dispensers that distribute virtually any assembly fluid — from thin solvents to thick silicones and brazing pastes — with the utmost precision. EFD air-powered fluid dispensers deliver exceptional throughput and process control, with consistent deposits from beginning to end.
  • Optimum syringe barrel systems, which feature Zero Draft barrels, SmoothFlow pistons, and precision-molded adapter assemblies, end caps, and tip caps that work together to produce accurate, repeatable fluid deposits.
Tagged With: Nordson
