  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Novotechnik introduces new programmable angle sensors
By Mike Santora | May 5, 2020
Novotechnik-vertx-37e-cmyk-300Novotechnik U.S. introduces the Vert-X 37E Series of programmable touchless rotary sensors. These sensors use a magnetic pick up that is secured to the rotating object, so that there is no direct mechanical linkage between the shaft and the measuring system, and therefore no wear.
The Vert-X 37E Series is hermetically sealed, without any moving seals, to IP68 and therefore provides long life even under the harshest water, dust, and oil environments.
Vert-X 37E Series can be programmed by customers or at the factory for the slope of the linear output, zero and end-points, mid-point, and switch steps, so customers can order angle sensors optimized for their specific application. These sensors can help achieve time and cost savings by eliminating the need for other components to specify the angle endpoints, choose an intermediate plateau, sense of rotation function, CW, or CCW or create V-output.
Key specifications for Vert-X 37E include 0 to 360° measurement range limits, 5V, and 24V supply versions, up to two switch outputs, resolution to 14-bit, linearity is ≤ ±0.3% and repeatability of ≤ 0.1°. MTTF is over 50 years. Output options include 4 to 20 mA, 0.1 to 10 V, 0 to 4.5 V, 10 to 90% of supply voltage, SPI, and PWM. Redundant output versions are offered as well.
Vert-X 37E Series sensors are absolute sensors so they retain their values even after power interruptions. They have compact designs of 1.45-in. diameter. Other Vert-X Series’ sensors are available which have larger or smaller dimensions depending on the model.
Novotechnik U.S.
www.novotechnik.com/vx37E
MOTION DESIGN GUIDES
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High Strength, NASA Low Outgassing Approved Epoxy
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
