Novotechnik launches new compact angle sensors
By Mike Santora | December 5, 2019
Novotechnik-VX1600-CMYKNovotechnik, U.S. introduces the Vert-X 1600 Series of sensors that measure angular position and are compact housing base diameter of 16 mm.
Vert-X 1600 Series sensors These sensors convert rotational angle into an analog or digital output. Measurement range is 0 to 360° with 14-bit resolution and repeatability of 0.1°. Available analog outputs are 10 to 90% of supply voltage and 5 – 95% of supply voltage. Digital interface options include SPI and PWM.
The sensors are sealed to IP 65, life is ≥ 50 million movements and MTTF is 668 years. Redundant versions of the Vert-X 1600 are available. A 6 mm D-Shaped shaft and two reinforced through-holes enable easy mounting.
These sensors are suitable for industrial, medical, off-highway vehicle, and other applications with an operating temperature range of -40 to +125°C will operate with up to 10 N axial or radial shaft load.
Novotechnik U.S.
www.novotechnik.com/vx1600
Filed Under: Sensor Tips
Tagged With: Novotechnik U.S.
