    • Subscribe!
NPArm Series Rack Mount Multi-Axis NanoPWM Drive Module
By PD&D Staff | August 11, 2016
ACS Motion Control has expanded its family of multi-axis NanoPWM™ to include the NPArm, a fully integrated 19” / 6U rack mounted version with up to eight drives and a power supply.
“ACS has developed the NanoPWM family of PWM drives to provide a more compact and economical alternative to linear servo drives for applications such as wafer metrology and inspection, ultra-precision machining for processing of optical components and FPD inspection, that demand the ultimate performance with regards to stand still jitter, low velocity tracking errors and the fastest move and settle,” said Ze’ev Kirshenboim, ACS Motion Control President.
Key Features
  • operates with any motion controller supporting a ±10V sinusoidal current commutation command interface
  • dynamic range of more than 100db (100,000:1)
  •  up to four pairs of two-drive plug-in modules with output current range between 3.3/10A and 13.3/40A (continuous/peak)
  • a 3.2kW power supply with single or dual output voltages, providing 48V or 96V or both
  • supports three-phase and single-phase servo motors
  • current loop can be tuned via DIP switches or fine-tuned using the ACS’ SPiiPlus MMI Application.
For more information, contact:
ACS Motion Control
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
    • Subscribe!
