Arinc 600 NSX receptacle connector from Radiall, Tempe, Ariz., features selective gold plating and new monoblock insert technology that helps reduce costs, without compromising performance.
A unique 3-points contact technology provides better electrical connection and more efficient re-alignment of the pin contacts. The insert supports basic movement of the contacts inside the cavity to provide mechanical play and offer same mating force as traditional Arinc 600 connectors.
It is available for receptacle connectors with 100 and/or 150 point insert arrangements in four different contact lengths. It is rated for temperatures from –65° to 125°C for 1000 hours. In addition, it has been tested for a variety of harsh environmental conditions, such as salt spray, moisture resistance, running water and fluid resistance.
Radiall USA Inc.
www.radiall.com
The post NSX connector features 3-points contact technology appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips
