  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
NTN’s Sentinel Series decreases downtime at poultry processing plant
By Mike Santora | October 5, 2020
NTN-poultry-processing-plantOne of the United States’ largest poultry producers was suffering production crippling bearing failures on its cropper machine caused by water ingression. Failures were occurring on a monthly basis, accounting for over $33,750 in lost production per month. NTN’s engineering and sales support team performed a comprehensive evaluation of the cropper machine and identified 15 bearings susceptible to failure due to corrosion caused by exposure to water.
NTN’s team recommended that the 15 bearings identified be replaced with Sentinel Series ball bearings. The company’s Sentinel Series features corrosion-resistant stainless steel ball bearings with seals and NSF H1 registered solid lubricant. The solid lubrication provides up to 21 times better wash-out resistance than standard grease and the seals provide improved protection over standard deep groove ball bearings, which is critical to extending the life of equipment exposed to moisture.
The NTN solution reduced annual failures on the cropper machine from 180 down to 30, nearly an 85% reduction. Rather than incurring monthly downtime due to corrosion, the NTN solution lasted six months before replacing the bearings was even considered. The increased uptime, reduced maintenance, and decrease in bearing spend resulted in over $343,000 in savings in the first year for the poultry processing plant.
FEATURES:
• Food-grade solid lubricant eliminates maintenance, resists wash-out
• Stainless steel or thermoplastic housings with stainless steel inserts prevent corrosion from moisture and harsh cleaning agents
• All units come equipped with your choice of open or closed cover configurations
NTN
www.ntnamericas.com
MOTION DESIGN GUIDES
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
  • Create your perfect machine with Advanced Engineering
  • How a ME/EE turned passion for design into his own bike company
  • Everyone Can Save on Cable Costs. Here’s How
  • How and Why You Should Use a Wave Spring for Bearing Preload
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
