NUTEC introduces a new generation of linear translation stages suitable for most positioning applications. This design features three different screw drives and ten different travel length from 50-500mm. The compact envelope of 50x100mm with easily accessible external mounting holes and bottom tapped holes allows a multitude of installation options in any attitude. For installation, order with optional Toe Clamps for easy and quick mounting. The preloaded recirculating precision guide rails have moment loading capability in every direction and provide a stable platform with constant support geometry for excellent trajectory.
The screw drive options include recirculating ballscrew drive, leadscrew & polymer nut and rolling motion only roller leadscrew. In conjunction with the standard and high precision version, the stage covers precision grades throughout the whole spectrum from low to high accuracy. The standard version is ready for a #17 NEMA frame size motor with #23 size and other custom motor interfaces optional, including both servo and stepper motors. The three LED sensors for home and limit sensing are interconnected at the rear bulkhead with a DB connector.
The 3-sided cover is an excellent protective device with a labyrinth seal for normal, harsh, clean room or vacuum environments. Available in stainless steel or black finish. Auxiliary accessories can be mounted on the external T-Slot groove, like linear encoders or other customer supplied devices.
NUTEC COMPONENTS, INC.
www.nutecomp.com
Filed Under: Factory automation, Encoders • linear, Linear motion • slides, Motion control • motor controls, Stages • gantries
