Nylon Plastic Solid Disk Handwheels
By Design World Staff | September 12, 2008
NEW BERLIN, WI — J. W. Winco, Inc. announced it has expanded its offerings to include Solid Disk Handwheels with Revolving Handle.
These glass-filled, nylon plastic handwheels with revolving handle are of modern design. An excellent choice for light to medium duty applications, they have a maximum heat resistance of 110‚°C (230‚°F). Countersunk washers for handwheel retention and modifications such as inch and metric bores, keyways, and set screw holes, are available upon request.
The body of the handwheel comes in a matte black finish, while the hub is zinc-plated steel, and molded in to the handwheel. The revolving handle is constructed of a black, fiber-reinforced, nylon plastic hand piece with a zinc-plated steel threaded spindle. Both inch and metric dimensions are interchangeable.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins, Mechanical
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
