The elegant new SLIM-CASE for mobile devices is now available in a smooth-top version for installing displays, push buttons and LEDs. The ergonomic SLIM-CASE (IP 54/65) is the new-generation handheld enclosure for mobile measuring and control applications, wireless communications, IoT/IIoT, healthcare, laboratories, offices, safety engineering and environmental technology.
The SLIM-CASE underlines its aesthetic credentials with a virtually frameless, low-profile design and soft contours that enhance the ergonomics. There is plenty of space inside for PCBs, plug connectors, interfaces and sensors.
In addition to the smooth-top version, there is also a 0.039-in recessed top for product labels or a 0.062-in recessed top for a touchscreen or membrane keypad. Each of the three variants can be specified with or without a soft-touch TPE intermediate ring for extra comfort and impact protection. This offers a choice of six versions in total.
The SLIM-CASE can accommodate inductive charging with the correct coil and NFC technology with Qi chargers. Power can be supplied by a flat battery mounted on the PCB.
The enclosures are available in one plan size (M) – 5.826×2.913 in – and two heights: 0.748 in (without TPE ring) and 0.866 in (with TPE ring). Inside there are PCB mounting pillars in both the top and base.
SLIM-CASE is molded from tough, UV-stable ASA+PC-FR (UL 94 V-0) for indoor and outdoor use. For added security, the enclosures are assembled using tamperproof Torx T8 stainless steel screws. The cases’ standard color is off-white (RAL 9002). Prices start at $18.
Accessories include an IP 65 seal for cases without the TPE ring, a transparent front screen (for use with touchscreens), an adhesive foil (for securing the screen), self-tapping PCB screws and a Torx T8 screwdriver.
OKW can supply SLIM-CASE fully customized. Services include custom colors for the main case and TPE ring, machining, lacquering, printing, laser marking, product labels, RFI/EMI shielding and installation/assembly of accessories.
OKW Enclosures, Inc., 3000 Old Pond Road, Bridgeville, PA 15017, (412) 220 9244, Fax: (412) 220 9247, E-mail: [email protected], www.okwenclosures.com/en/Plastic-enclosures/Slim-Case.htm
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
