TOPTEC plastic enclosures for PCBs with protruding connectors and interfaces are now available in 28 different permutations. TOPTEC is a good candidate for applications including monitoring, signaling and control systems; medical and wellness devices; laboratory technology; computer peripherals and IoT/IIoT.
Installations are faster because pre-assembled PCBs fitted with protruding
connectors or interfaces can be mounted directly into the case – with no need to wire them in afterwards. The enclosures simply snap together (but for security, a tool is needed to open them).
These smart, modern ABS (UL 94 HB) enclosures can be used for desktop, wall-
mounted or DIN rail electronics. The base’s wide lateral opening offers excellent access to components. Clip-in end panels allow connectors to fit straight in. The lid is recessed for a membrane keypad or product label. Inside there are screw pillars for PCBs.
TOPTEC is available in two types: F (flat top) and H (high top) – either with or without slots for ventilation, gas detection or sound. F enclosures are available in four plan sizes: 4.02×2.13 in, 4.84×2.68 in, 6.06×3.31 in and 7.64×4.53 in. H cases can be specified in all but the smallest plan size.
There are two standard colors: off-white (RAL 9002) and black (RAL 9005). Prices start at $19.
Accessories include: concealed wall suspension elements (click to fit installation, with fast release tab), DIN rail fastening clips (TH35, G32), anti-slide rubber feet and self-tapping screws for mounting PCBs.
OKW can supply TOPTEC fully customized. Services include CNC machining,
lacquering, printing, laser marking, decor foils, special materials, RFI/EMI shielding and installation/assembly of accessories.
OKW Enclosures, Inc., 3000 Old Pond Road, Bridgeville, PA 15017, 412 220 9244, Fax: 412 220 9247, E-mail: [email protected], https://www.okwenclosures.com/en/Plastic-enclosures/Toptec.htm
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
