Transparent-lid industrial enclosures now come in PC – 16 sizes
By Lee Teschler | August 5, 2020
OKW has further expanded its range of IN-BOX industrial electronic enclosures. The transparent-lid version is now available in polycarbonate (PC) for extra strength and flammability resistance.
These widely used and tough plastic enclosures for terminal installations suit a wide range of applications including OKW transparent liddigital and analog instrumentation, sensors, interfaces, security systems, HVAC, machine building, construction equipment, Smart Factory and Industry 4.0.
IN-BOX offers high levels of impact resistance (IK07/08) and ingress protection (IP 66/67); the sealing gasket is pre-foamed in the top. Quarter-turn stainless steel lid screws speed up installation and maintenance.
The enclosures can be mounted on a wall, either directly or with brackets (accessory) for external installations. Inside, there are screw pillars for DIN rails, PCBs and mounting plates.
IN-BOX is available as standard in light gray (RAL 7035) in a choice of high-gloss plastics: ABS (UL 94 HB, IK07) or polycarbonate (UL 94 V-2, IK08). The transparent-lid versions can be specified in either ABS/PC or now PC for higher impact and flammability ratings. The PC enclosures comply with fire safety standard UL 94 5V (better than V-0), although the material has only the classification V-2.
Three versions of IN-BOX (opaque lid ABS, transparent lid ABS/PC and new transparent lid PC) are available in 16 sizes from 3.30×3.22×2.16 in to 11.88×9.13×4.33 in. An opaque lid PC version is available in 10 sizes from 3.30×3.22×2.16 in to 11.88x 9.13×4.33 in. Prices for the new models start at $20.
Accessories include pressure equalisation elements, cable grommets, security kits, wall-mounting brackets, internal hinges, mounting plates, DIN rails (TH15, TH35) and self-tapping screws for mounting assemblies inside.
OKW can supply IN-BOX full customized. Services include CNC machining, printing of parts and labels, laser marking, decor foils, RFI/EMI shielding, installation and assembly.
OKW Enclosures, Inc., 3000 Old Pond Road, Bridgeville, PA 15017, 412-220-9244 Fax: 412-220-9247, E-mail: [email protected]losures.com, https://www.okwenclosures.com/en/Plastic-enclosures/In-Box.htm
You may also like:
  • What is flux braking and how does it differ from…
  • How the requirements of the cars of the future change…
  • What is a gated index pulse for incremental encoders?
  • How do sensors make a building more comfortable?
  • Understanding 3DP: Selecting the right process and material for you
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
Tagged With: okwenclosures
55416_commModule_APL_300dpi_cmyk
Softing introduces a hardware module for implementing Ethernet-APL field devices.
IO-Link Smart Field I/O System from AutomationDirect
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
