Wall-mount enclosures for control units and network nodes
By Lee Teschler | April 14, 2020
OKW has created a new version of its NET-BOX wall mount enclosures for control units and network nodes. The mounting points on the rear section of the enclosure are now pre-drilled ready for the wall mounting screws — making it quicker and easier to install the electronics device in situ.
NET-BOX is a slim, elegant housing for applications including IoT/IIoT, Smart Factory, Industry 4.0, building management, central okwcontrol units, gateways, data acquisition, data systems engineering, measurement and control, supervision terminals, access control, medical and wellness technology.
New Version II offers all the outstanding technical features of the existing models but is pre-drilled with three wall mounting points. There is no need to open the main electronics section. Only the front lid has to be refitted after installation. The base section has screw pillars for mounting PCBs.
Both versions of NET-BOX feature a stylish curved top with a front lid that conceals cables and connectors. The three-part construction ensures no screws are visible at the front. Anti-tamper Torx T10 screws are supplied as standard.
NETBOX Versions I and II are available in three sizes: 5.51×5.51×1.83 in, 7.09×7.09×1.91 in and 8.66×8.66×1.99 in. They are molded from UV-stable ASA+PC-FR (UL 94 V-0). The base section is lava gray as standard with a light gray (RAL 7035) top cover and lid. Prices start at $36.
Accessories include infill covers (which close the bottom of the enclosure and can accommodate a further PCB), IP 65 sealing kits, anti-slide feet, self-tapping screws and a Torx T10 screwdriver.
OKW can supply NET-BOX fully customized on request. Services include CNC machining, lacquering, digital/screen/tampo printing or laser marking of legends and logos, decor foils, RFI/EMI shielding, installation and assembly of accessories.
Visit the OKW website for further information: https://www.okwenclosures.com/en/Plastic-enclosures/Net-Box.htm
Filed Under: Cabinets • enclosures • control panels • DIN rail
Tagged With: okwenclosuresltd
