Elegant new SMART-PANEL wall-mount enclosures are for intelligent building control and monitoring technology. The attractive and ergonomic SMART-PANEL line is designed to house modern control consoles in a wide range of residential, commercial and industrial applications. They include building services systems, electrical installations, smart home, IoT/IIoT, wireless
communications, measuring and control, medical and laboratory technology, security and access control.
There are no visible fixing screws because the top snaps into place – speeding
installation and servicing. The top can be re-opened using a set of push-in opening tools (accessory). The large recess in the top can accommodate a touchscreen, display or membrane keypad.
The bottom part fits standard flush-mounted/cavity wall boxes (maximum opening 61 mm) and larger international installation boxes (up to 5.90-in high and 2.40-in wide). Electronic components mount in the top part. A snap-in phenolic resin hardboard protection plate (accessory) safeguards the underlying electronics from the risk of damage during installation and servicing.
The SMART-PANEL enclosures are available in two sizes: 3.30×3.30×0.83-in and 6.10×3.30×0.83-in. They are molded from UV-stable ASA+PC-FR (UL 94 V-0) with a highly polished bottom part and a fine-textured top. The standard color is traffic white (RAL 9016). There is a flat, recessed area in one end for USB and Mini-USB connectors etc. Prices start at $19.
Accessories include a glass panel (which can be printed on the rear) for touchscreens and displays; a set of opening tools; hardboard protection plates, adhesive foils and anti-slide feet for desktop use.
OKW can supply SMART-PANEL fully customized. Services include CNC machining,
printing, laser marking, RFI/EMI shielding and installation/assembly of accessories.
OKW Enclosures, Inc., 3000 Old Pond Road, Bridgeville, PA 15017, 412 220 9244, Fax: 412 220 9247, E-mail: [email protected], https://www.okwenclosures.com/en/Plastic-enclosures/Smart-Panel.htm
You may also like:
Filed Under: Cabinets • enclosures • control panels
