Omega Engineering won an Honorable Mention in the recently completed 2022 Leap Awards for product innovation.
The LEAP Awards celebrates the most innovative and forward-thinking products serving the design engineering space. Omega Engineering won in the Sensors and Switches category covering equipment feedback devices such as mechanical switches and photoelectric, proximity, reel, and hall-effect sensors. Submissions also included devices for pressure, speed, temperature, and vibration sensing, vision systems, and edge devices.
Omega Engineering’s high-accuracy non-invasive HANI Clamp-On Temperature Sensor is the first-ever technology to achieve the precision performance of an invasive sensor from a surface-mount design. HANI attaches to piping systems in seconds, no tools required, without interrupting flow or production. This quick and unique installation process eliminates the downtime that is inherent with other sensors of this caliber, which almost always require time-consuming design, drilling, welding, and testing prior to use.
HANI sensors require zero contact with products such as foods, liquids, and creams, which can cause accuracy drift, flow and clog issues, sensor deterioration, and breakage, and contamination risk. Available for use on metal and plastic pipes (soon available for glass), plus sanitary models for hygienic systems, HANI improves the effectiveness of CIP, pigging systems, and other cleaning processes while reducing product waste as compared to invasive probes. Get the performance of invasive probes with less hassle and lower total cost of ownership with high-accuracy non-invasive HANI Clamp-On Temperature Sensors.
Filed Under: Sensor Tips
