Omega’s new exclusive M12CM series of M12 cables with compensated connectors for thermocouples feature a straight and right angled M12 field mountable connector sensor end, compensated thermocouple cable, sockets and pins, and two cable insulation options are available in IEC and ANSI color codes. The M12CM series have a variety of connection methods to work with your instrumentation. This product is ideal for process control applications especially where the operating temperature exceeds the limitations for standard M12 cables and sensors.
Omega
www.omega.com
The post OMEGA Introduces Cables with Compensated Connectors for Thermocouples appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips, Connectors (electrical) • crimp technologies
