OMEGA Releases Dual Channel Virtual Chart Recorder
By Editor | November 20, 2012
The OMEGA® iTHX-SD-5D Datalogger records temperature, relative humidity, and dew point over an Ethernet network or the Internet and locally on an SD card.
The new dual channel feature allows for measurement of data from two locations. For example: you can measure and chart temperature and relative humidity of your local area and temperature and humidity of another location 10 feet away.
The device can trigger an alarm if the temperature or humidity goes above or below a set point that the user determines. The alarms can be sent by email to a single user or to a group distribution list, including text messages to cell phones and PDA’s.
The iTHX-SD comes complete with a removable 2 GB SD Flash Memory card that can store up to seven years of readings taken at ten second intervals. The data is recorded on widely available SD (Secure Digital) flash cards. The format is a simple text file that is easily imported to spread sheets and other programs. It can be read directly on a PC or MAC with a USB card reader. You can also download the data remotely over an Ethernet network or the Internet.
OMEGA
www.omega.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
Tagged With: Omega
mti
MTI
moog
