A high-coded non-contact door switch installs quickly in new or existing production environments.
To prevent tampering and simplify installation, each Omron D41D is uniquely coded. Pairing via RFID is automatic and requires less than 30 seconds. Up to 30 switch sets can be wired in series and paired at the same time. Integrated LEDs provide real-time status and diagnostic information.
To accommodate constricted spaces, OEM/Machine operators can configure the D41D with flat or miniature actuators. Both the switch and actuators meet the IP65 (water) and IP67 (immersion) ratings. They also comply with IEC 61508 (Safety), ISO 14119 (Type 4/High Coded), and ISO 13849-1 (PLe).
Installation, component pairing, and commissioning are simple and intuitive. These efficiencies help projects go live quickly and deliver a lower total cost of ownership. High reliability enables facility owners to focus on best safety practices and risk-reduction strategies.
Also available is a new guard lock with ergonomic door handle that installs quickly in production environments. Omron’s D41G guard lock is a cost-effective solution that uses a familiar door-handle design to control the lock actuator. Where necessary, integrators also can configure the guard lock with an inside mechanical release handle. Handles further enhance safety by giving operators an intuitive way to rapidly unlock doors or gates.
The D41G uses a high-level coded RFID sensor to monitor gate or door position. Because the switch sensor and the actuator are uniquely coded, it is very difficult for operators to bypass the lock by using a spare actuator.
The D41G complies with the ANSI/RIA 15.06 standards for integrating robots into factories and other work areas. It also complies with IEC 61508 (Safety), ISO 14119 (Type 4/High Coded), and ISO 13849-1 (PLe).
Another version is a hygienic guard locking switch for controlling access to hazardous and hygiene-sensitive machines and areas. The D41L hygienic guard locking switch uses a high-level coded RFID sensor to monitor gate or door position. Because the switch sensor and the actuator are uniquely coded, it is difficult for operators to bypass the lock by using a spare actuator.
The locking switch enclosure is ECOLAB certified and meets IP66 (water jets), IP67 (immersion), and IP69 (dust) ratings. While a smooth surface prevents debris from accumulating, it can be cleaned with detergent if necessary. It complies with ISO 14119 (Type 4/High Coded) and ISO 13849-1 (PLe).
Installation, component pairing, and commissioning is simple and intuitive. These efficiencies help projects go live quickly and deliver a lower total cost of ownership. High reliability enables facility owners to focus on best safety practices and risk-reduction strategies.
The D41L offers automatic pairing. Pairing by teach (individual coding and single or multiple teaching) requires only 30 seconds. Integrators can select mechanical power-to-lock or solenoid power-to-unlock versions. LEDs provide smart diagnostics, and up to 31 devices can be connected in series.
Omron Americas, 2895 Greenspoint Pkwy., Ste 200, Hoffman Estates IL 60169, automation.omron.com/
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
