One device, two temperature instruments
By Paul Heney | November 18, 2020
Ashcroft’s Model K dual sensor thermometer combines two independent temperature sensing devices into a single instrument.
For local indication, a silicone-dampened mechanical ANSI/IEC/EN classified bimetal system drives the pointer over an 80-, 100-, 130-, or 150-mm diameter dial. The choice of a stem from 90mm to 2000 mm also contains a type K thermocouple to signal a remote readout, data acquisition device or control system.
While providing these two distinct capabilities, the Ashcroft Model K only requires a single process connection point. This multi-capable design will save both installation time and the cost of purchasing two separate instruments.
Ashcroft
www.ashcroft.com
Filed Under: Gages
Tagged With: ashcroft
Paul Heney
