Used on hexagonal shafts
Smooth bore protects shafts from damage
Superior holding power over set-screw type collars
Exclusively stocked by Stafford, these collars fit on standard hexagonal shafts. They can be modified (drilled, tapped, welded, etc.) to act as mounts for other components.
1-Piece Clamp-Type Shaft Collars are precision machined, non-marring, easy to adjust, with high clamping power.
Stocked in:
Steel
Stainless Steel
Stafford
shaft-collars-couplings.staffordmfg.com
Filed Under: Coupling Tips
