The SCHUNK KONTEC KSC centric clamping multifaceted vise has optimal jaw support for I.D. and O.D. clamping with long base jaw guidance. It can be easily adapted for conventional clamping, short clamping depths for 5-sided machining, mould parts, plates or saw cuts.
This innovative vice has already set itself apart on the market because of its functionality and affordability.
The KSC is known for high precision and process reliability. A pre-tensioned and backlash-free center bearing and an extra fitted slide guarantee a repeat accuracy of ±0.01 mm and enable the precise processing of the first and second side in a clamping system.
An integrated chip drain and a protected spindle assure maximum process reliability. The centric clamping vise is ideally suited for affordable storage solutions in automated machine tools.
The new vise is available with jaw width of 80, 125, and 160 mm with two base body lengths from 130-480 mm.
The post One vise for all workpieces with jaw support for ID and OD clamping appeared first on Robotic Tips.
Filed Under: The Robot Report
