The free humidity calculator from E+E Elektronik is used for the rapid conversion of humidity measurements. You can fast and quickly calculate from temperature and relative humidity the dew point, frost point, mixing ration or other humidity measurements with ease.
Uniquely, the humidity calculator also includes measurement uncertainties in the calculation. This is helpful for obtaining realistic and reliable overall uncertainties based on the specification of the measuring device.
The humidity calculator can be used online. This does not require any program to be installed on your PC.
E+E Elektronik
www.humidity-calculator-online.com
Filed Under: Test + measurement • test equipment
