The new CC3000 Operator Interface Enclosure System protects operator interface terminals and electronic monitors in UL Type 12 industrial environments against dust, dirt, dripping water, and non-corrosive liquids. It is UL-rated for indoor use. Applications include process control, system integration, robotics, material handling, wastewater processing, and oil and gas processing.
Users can select from four standard models sized to fit HMI tools, including flat-screen devices, lights, meters, and gauges. Custom options are also available.
The modular 120 mm and 200 mm solid body depth profile units use single-wall aluminum construction to dissipate heat and eliminate thermal buildup inside the enclosure, which often eliminates the need for active cooling.
Options include: a 55mm hinged door extension for the enclosure front or rear openings, five handle configurations, a USB connector accessory, as well as provisions for a keyboard, and more.
About Hoffman
Hoffman is a part of the Pentair Technical Products Group. The company is a leading designer and manufacturer of systems that protect the electronic controls and mission critical electrical systems in industrial, data communications, commercial construction, and government applications.
:: Design World ::
Filed Under: Cabinets • enclosures • control panels • DIN rail
