    • Subscribe!
Optical sensor measures distances to 5,000 mm
By Frank Tobe | February 20, 2015
SIKOWherever large quantities of a product are manufactured, automation measures have become indispensable. Production lines automatically detect materials passing by machines or equipment to be completed. Whether in automobile production, steel processing or woodworking/furniture production, manufacturing steps and production processes are bound up with the need to measure spaces and distances. In addition to the manufacturing field, material handling and storage technology are also relevant fields of operation for the optical distance sensors.
The optical Distance Sensor LT5000 works with a laser light based on Time-of-Flight technology. The distance is determined by a pulsating laser light emitted from the sensor head and reflected back from the object at the distance being measured. Based on the time between the moment the laser light is emitted and the moment it is received back, the distance to the object can be determined. This principle is similar to that used by a “laser pistol” used by police to measure speeds in roadway traffic.
The sensor head has an analog voltage/current output. The area to be measured can be configured by pressing buttons and can also be inverted, if necessary. With the help of an additional switching output, the switching range can be adjusted as desired.
SIKO
Contact:
SIKO Products, Inc
2155 Bishop Circle E
Dexter, 48130 Michigan
Tel: 734 426 3476
Fax 734 426 3453
www.siko-global.com
siko-global.com
Filed Under: TECHNOLOGIES + PRODUCTS, Sensors (position + other)
Tagged With: siko
CIT
Relays feature 1.8-mm contact gap to meet IEC safety standards
New economical linear modules for lighter loads
Ethernet remote I/O modules add Conditional Logic Computing
Self-contained actuator for a variety of applications
    • Subscribe!
