Options for coupling two parallel shafts
By Mike Santora | October 15, 2019
Inertia-Dynamics-Family-of-ClutchesPower-on Clutches are used to couple two parallel shafts. The armature hub assembly is mounted to the same shaft as the rotor assembly. The armature hub accommodates a pulley, gear, sprocket, etc., to transmit torque to the second shaft. The field assembly is mounted on the shaft and retained by a loose-fitting pin or bracket through the anti-rotation tab.
Typical Applications of Clutches include:
  • Packaging Machinery
  • Medical Equipment
  • Conveyors
  • Postal Sorters/Readers
  • Document Feeders
  • Textile Equipment
  • Mobile Power Equipment
  • Copiers/Printers
Electromate offers a full family of Power-On Clutches, from Inertia Dynamics, for most applications.  All Inertia Dynamics clutches are recognized by Underwriters Laboratories to both U.S. and Canadian safety requirements.
Electromate
www.electromate.com
Filed Under: Coupling Tips, Flanges • supports • mounts • brackets
Tagged With: electromate
Sensata Technologies adds Predictive maintenance for rotary equipment
KTR RUFLEX torque limiter with BoWex gear coupling
Ringfeder on Carlyle Johnson JEB electric jaw clutches
KTR EVOLASTIC highly flexible coupling
