    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
Opto 22 Introduces SNAP TEX Product Line
By Design World Staff | July 1, 2008
Temecula, CA – Opto 22 has introduced the SNAP TEX family of mounting and wiring accessories, which includes a wide variety of terminal extender cables, breakout boards, wiring harnesses, DIN-rail kits, jumper straps, rack adapters, and other components for mounting and wiring Opto 22 automation, control, and I/O systems.
Wiring, installing, and assembling control and I/O systems is often expensive and time-consuming for end-users, original equipment manufacturers (OEMs), panel builders, system integrators, and others. Installers must also be careful to avoid mixing terminations, particularly in cases where several hundred devices terminate in a single cabinet. The SNAP TEX line was created to address these issues by significantly reducing the time, expense, and complexity associated with field instrumentation wiring and control cabinet assembly.
The first products in the new SNAP TEX line are SNAP TEX cables, six feet (1.8 m) long jacketed, pre-wired cables that provide neat, bundled connections from analog and digital I/O modules to field devices, terminal strips, and breakout boards. SNAP TEX cables snap neatly into the tops of SNAP I/O modules and terminate with color-coded flying leads, pre-stripped and tipped, ready for wiring. By providing snap-in, easy-to-trace wiring from the module to the device, SNAP-TEX cables reduce wiring mistakes, protect terminal connections from dust and jarring, and also speed and simplify both initial wiring and subsequent maintenance and replacement.
Three versions of SNAP TEX cables are available, varying based on the internal bus connections required by the application. Customers have a choice of cables with even-numbered terminals commoned (SNAP-TEX-CBE6), odd-numbered terminals commoned (SNAP-TEX-CBO6), or with wiring straight through (SNAP-TEX-CBS6).
Next in the SNAP TEX product family are several new breakout boards. The SNAP-TEX-32 is a simple 32-channel breakout board with straight-through connections, designed primarily for use with the aforementioned SNAP TEX cables and SNAP analog or digital I/O modules.
The SNAP-TEX-FB16-H and SNAP-TEX-FB16-L breakout boards offer 16-channel terminations and provide a fuse and a fuse-blown indicator for each channel. With the use of an external power supply, these breakout boards also bus power to loads. The SNAP-TEX-F16-H facilitates 120-240 volts, and the SNAP-TEX-F16-L works with 12-24 volts. These breakout boards are used for digital inputs and outputs.
The SNAP-TEX-MR10-16 and SNAP-TEX-MR10-4 breakout boards are designed for high-current output switching. These boards feature mechanical relays that switch up to 10 amps per channel, expanding the switching ability of standard SNAP I/O modules by 13 times. These boards include on/off indicators for each channel, and each can be wired as normally closed or normally open.
Rounding out the new SNAP TEX line is an assortment of wiring harnesses (used for connecting field devices to high-density SNAP I/O modules), jumper connection straps (used with digital I/O modules), DIN-rail mounting kits, module removal tools, and other accessories. Moving these previously available accessories under the SNAP TEX line will help customers find the right parts for all of their wiring and installation needs.
www.opto22.com
Filed Under: Cables + cable management, Data acquisition + DAQ modules, Factory automation, I/O modules, Connectors (electrical) • crimp technologies, Motion control • motor controls, Terminal blocks
  • What DRC Reports Tell You and What They Don’t
  • Big growth in U.S. industrial automation
  • Siemens aims for 80 percent automation in German plant
  • Tech Toolbox: Machine design for food automation
  • Tech Toolbox: Machine design for packaging
    • On the Floor
  • Advertisers
    • PR Submissions
