Opto 22 releases new groov EPIC I/O modules for large-scale power monitoring, signal integration
By Paul Heney | December 9, 2021
Opto 22 has announced two new I/O modules for its groov EPIC edge programmable industrial controller: GRV-IVAPM-3 for Category III three-phase AC power monitoring up to 600 VAC and GRV-MM1001-10 for universal I/O sensing and control.
Cost-effective power monitoring and I/O signal integration are fundamental requirements for large-scale digital transformation. Opto 22’s new module options allow engineers, developers, and digital transformation leads to collect power and energy data, machine performance, and asset status directly from field devices and equipment and transport it securely into backend systems.
GRV-IVAPM-3
With simple web-based configuration, the GRV-IVAPM-3 module captures Category III AC voltage, current, energy, and power measurements, facilitating preventative and predictive maintenance and energy optimization cost-saving initiatives.
The module can separately measure up to 3 different single-phase (two-wire with neutral) branch circuits from the same service or a single 3-phase wye (up to 400 VAC) or delta (up to 600 VAC) circuit. Engineers can use either 0.333 VAC, 1 VAC, or 5 A Category III current transformers (CTs) for current measurement and, if necessary, can use a different CT type on each circuit.
GRV-IVAPM-3 provides 18 real-time data points per phase — including voltage, current, true and reactive power, power factor, and frequency — and 10 additional data points providing totals across all three phases. Accumulated values are preserved in non-volatile memory every 30 seconds to survive power interruption, and signal accuracy can be tuned for each phase using the minimum voltage threshold ratio, minimum current threshold ratio, and power creep adjustment properties.
GRV-MM1001-10
Based on Opto 22’s successful groov RIO edge I/O module, the new GRV-MM1001-10 module for groov EPIC gives engineers the flexibility to quickly connect almost any traditional I/O signal or circuit they find in the field without specifying precise sensing requirements in advance.
This software-configurable universal I/O module accepts over a dozen signal types—analog and discrete, inputs and outputs. It supports over 200,000 unique I/O configurations via eight multifunction, multi-signal I/O channels, including thermocouples (TCs), integrated circuit temperature devices (ICTDs), thermistors/resistors, voltage inputs/outputs, current inputs/outputs, millivolt inputs, discrete DC inputs, self-wetting discrete inputs, and discrete DC sinking outputs. It also includes two form C mechanical relays.
groov RIO modules can be used in combination with GRV-MM1001-10 modules on groov EPIC to provide both universal remote and local I/O capabilities, accelerating signal integration for large facilities and remote sites.
Both of Opto 22’s new modules provide signal quality indicators and intelligent functions like scaling, averaging, and totalizing. Once acquired, data from both GRV-IVAPM-3 and GRV-MM1001-10 is immediately available for distribution to backend applications through the groov EPIC processor’s embedded MQTT clients, Ignition Edge from Inductive Automation, REST API, and traditional industrial communication protocols.
Availability
GRV-IVAPM-3 ($895) and GRV-MM1001-10 ($895) modules are available through Opto 22’s global network of distributors and system integrators, and directly via +1-800-321-OPTO and www.opto22.com. groov EPIC firmware 3.3.0 and PAC Project 10.4 or a groov EPIC SSH license are required for full support, with CODESYS support coming soon. Free technical support is provided for all Opto 22 products from pre-sales through the life of the system.
Opto 22
www.opto22.com
Filed Under: I/O modules
Tagged With: opto22
Paul Heney
Paul J. Heney, the VP, Editorial Director for Design World magazine, has a BS in Engineering Science & Mechanics and minors in Technical Communications and Biomedical Engineering from Georgia Tech. He has written about fluid power, aerospace, robotics, medical, green engineering, and general manufacturing topics for nearly 25 years. He has won numerous regional and national awards for his writing from the American Society of Business Publication Editors.
Io-link-Smartfield
IO-Link Smart Field I/O System from AutomationDirect
Beckhoff I/O terminal supports high-voltage measurement for renewable energy and EV technologies
Opto 22 releases groov RIO EMU distributed energy monitoring unit
lutze
Overload current-control module features super-thin form factor
