Optomec’s new LENS laser deposition head offers configurable optics
By Leslie Langnau | October 16, 2019
Optomec – a leading global supplier of production-grade additive manufacturing systems for the 3D printing of metals, announced the new LENS Laser Deposition Head (LDH 3.X), with a variable optics system that can create three discreet focused spot sizes to accommodate changes in laser power. The LDH 3.X supports a range of laser powers from 500 W to 3 kW to ensure optimal DED processing across a range of parts and applications.
“As metal additive manufacturing users continue to seek higher laser powers, faster speeds, and improved deposition rates to maximize production, they don’t want to sacrifice the quality of the build. Controlling power density during processing becomes a critical factor,” said Tom Cobbs, LENS product manager at Optomec. The LDH 3.X offers versatility, robustness, and ease-of-use to control laser power density at the workpiece.
The range of laser powers supported by the LDH 3.X is enabled by an advanced cooling system that allows for high-power duty cycles, and variable optics the user can control to keep processing optimal over the full range of laser power. With improved channeling for water cooling the head, the LDH 3.X will not overheat while operating at high powers and for long build times. Adding to the versatility of the head, the new LDH 3.X has a quick connect/disconnect nozzle system allowing for interchanging of nozzle types depending on the application (i.e. 4-tip, coax, high overhang, etc.)
By enabling users to vary the optics, create multiple focused laser spot sizes, use interchangeable nozzles and work with a range of laser powers, the LDH 3.X is effective for a variety of industrial applications including small to large builds, high deposition rates at high powers, repairs, coatings, and cladding operations. With LDH 3.X, a 0.6 mm focused spot size can be chosen for processing smaller parts or intricate feature building, then switched to 2 or 3 mm focused spot sizes for increased laser powers for larger builds or clad type operations.
The Optomec LENS LDH 3.X is available immediately for most Optomec LENS system models
Optomec
optomec.com
Filed Under: 3D printing • additive manufacturing • stereolithography, Vision • machine vision • cameras + lenses • frame grabbers • optical filters
Tagged With: optomec
PCB mills
September 2020 Special Edition: 2020 Additive Manufacturing Handbook
The Decision-Makers’ Guide to Additive Manufacturing: Explore the essentials of today’s AM environment and improve your results
Top 3 reasons why you should consider additive manufacturing today for production parts
