optoNCDT 2300LL High Speed laser sensor with anti speckle feature
By Test and Measurement Editor | October 24, 2012
Laser sensors of the series optoNCDT 2300LL use a very small laser line instead of the common laser spots. Due to this laser line, the optoNCDT 2300LL is also very well suited for precise distance and displacement measurement on glossy, porous or rough surfaces. Due to the high measurement rate of up to 49kHz it is possible to reliably apply the sensor in fast processes. The parameterization of the laser sensor is effected via web interface which is contacted via the Ethernet interface. Via the web interface numerous possibilities for the measurement value and signal processing are offered.
Details
  • Measuring ranges (mm):
    2 | 10 | 20 | 50
  • Linearity max 0.6µm
  • Resolution max. 0.03µm
  • Adjustable measuring rate up to 49.02 kHz
  • Interfaces: Ethernet, EtherCAT, RS422, analog via CSP2008 controller
  • Special optics for small laser line
  • Precise measurements on metallic and rough surfaces
  • Advanced Real-Time-Surface-Compensation (A-RTSC)
  • Integriated controller
Micro-Epsilon
www.mirco-epsilon.com
Test & Measurement Tips
Filed Under: Test & Measurement Tips, Vision • machine vision • cameras + lenses • frame grabbers • optical filters
Tagged With: Micro-Epsilon
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
