Oriental Motor now sells an expanded line of its popular BMU and BLE2 Series brushless dc motor with the addition of a new right-angle 60-watt (1/12 HP) model.
The new right-angle 60 watt (1/12 HP) brushless motor uses the BL5 motor and features an IP66 connector. It is combined with a hollow shaft right-angle hypoid JH gearhead, making this new model release the most compact right-angle brushless motor available in the brushless dc motor product group offered by Oriental Motor.
The BL5 brushless motor with this new connector offers IP66 degree of protection and allows for easy and direct connection between the motor and driver with two available orientation of cable outlet direction. The BL5 brushless motor with IP66 connector is also designed to work interchangeably with both the BMU and BLE2 speed controllers. This common BL5 motor design allows for maximum design flexibility.
The JH type hypoid right-angle gearhead offers a maximum rated torque of 138 lb-in. (15.6 N-m) through a stainless steel, metric output shaft with no permissible torque limit and a wide output speed range of 80 to 3,600 rpm.
Added value benefits include space saving features, increase maintenance-free performance, continuous flat torque, stable and wider speed control thanks to the brushless motor design advantage.
To learn more about Oriental Motor’s brushless DC motor speed control system line up, visit this deep link to the dc-motor product page at orientalmotor.com.
Since its founding in Japan in 1885, Oriental Motor has been a world leader in motion control systems. For over a century, we have concentrated on technological advancement and product design improvement — an emphasis evident in the sophisticated devices we market today.
