    • Subscribe!
Orion Fans Develops Easy Access Sliding and Hinged Versions of Louvered Fan Guards
By Taylor Meade | May 24, 2017
Orion Fans has expanded the industry’s lowest cost louvered fan guard product offering to include sliding and hinged versions. Designed to simplify installation and reduce maintenance time and cost, the heavy-duty LFGS Series sliding and LFGH Series hinged louvered fan guards make it easier to access and change filters. With standard filtering to 8 microns, Orion’s louvered guard filters are designed to prevent dust and dirt from entering enclosure applications. Other filter media types are also available.
The sliding (push/pull) and hinged (flip-up) louvered fan guards are available for use with 120, 172, 200, and 280mm fans. Orion’s broad louvered fan and fan guard offering allows customers to find the right solution for most any application.
Orion’s sliding and hinged louvered fan guards are also available as part of Orion’s Louvered Filter Fan Kit, which consists of a fan guard, filter, fan, metal guard, and hardware.
“Orion Fans provides the industry’s broadest and most cost effective line of fan accessories. Manufactured by Orion, these accessories make the procurement process easy and efficient, unlike other manufacturers who buy from third party vendors,” said David Luna, VP of Marketing at Orion Fans. “The new slide and hinged louvered fan guards simplify assembly time and reduce cost, as no additional hardware is required.”
Orion Fans
www.orionfans.com
Filed Under: TECHNOLOGIES + PRODUCTS
Tagged With: orionfans
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
Southco introduces stylish corrosion-resistant stainless steel positioning hinge
CIT
Relays feature 1.8-mm contact gap to meet IEC safety standards
New economical linear modules for lighter loads
    • Subscribe!
