Orion Fans expands IP55-rated AC motorized impellers family & adds new DC motorized impeller line
By Paige Beach | February 22, 2018
Orion Fans has expanded its AC motorized impeller product offering with 14 new IP55-rated models and has added a new line of 24V and 48V DC motorized impellers with 13 models. The AC motorized impellers provide high airflow for a wide range of harsh and demanding applications. The DC motorized impellers deliver a low power solution with standard control and monitoring features. The new motorized impeller models are available in popular 133mm, 175mm, 182mm, 220mm and 225mm sizes, expanding the existing range from 133mm to 400mm.
All AC motorized impellers are IP55-rated and ship standard with the required capacitor. All DC motorized impeller models include a PWM and Tachometer function as standard features. Optional metal duct rings are also available for both AC and DC models.
Featuring backward curved plastic or all-metal blades, sealed dual ball bearings, and rugged die-cast aluminum frame, the motorized impellers provide long-life, low-maintenance operation and offer superior maximum static pressure values for restrictive environments such as electronic cabinets, enclosures and ventilation systems.
“Our motorized impellers move a significant amount of air for their small size. With the expanded range offering, customers can now apply these to a number of high static pressure environments for a low-maintenance, cost-effective cooling solution,” said David Luna, VP of Marketing at Orion Fans.
The motorized impeller meets the demands of a wide range of applications, with custom packaging available for special requirements.
Orion Fans
www.orionfans.com
Tagged With: orionfans
