OSXL-101 Thermal Imager from Omega Engineering
By Dave Miyares | July 16, 2010
The OSXL-101 is a compact infrared thermal imaging sensor utilizing a thermopile array detector. The OSXL-101 sensor measures realtime temperature and a thermal image up to 300°C (572°F).
OSXL-101-Thermal-Imager
Ethernet connectivity allows the sensor to communicate with a PC running the application software or customers LAN. The unit has 2256 Pixel Resolution, Built-In Alarms, and a Mounting stand with a ball-socket fitting for full range of motion. An optional NEMA 4 (IP65) enclosure is available.
Omega Engineering
www.omega.com
Filed Under: Electronics • electrical, Sensors (position + other), Test + measurement • test equipment
molex-premo-flex
